Topic Title: cat5 & swa in parallel
Created On: 07 April 2011 12:15 PM
SandyBoiler
Hi folks,
I understand that it is a no-no to run power and data in parallel, I'm guessing the effect would be the data speeds would be reduced? Would you always code say, data cables run in parallel with a run of swa?
Andy B
 07 April 2011 12:22 PM
Could you support a Code with a regulation - 528.1 might do it depending on what the data circuit actually does, or possiby the Note 2 to 528.2
You might need to look in standards other than BS 7671 for an answer
 07 April 2011 12:47 PM
Legh
As long as the SWA is bonded - earthed then this might suffice.
I look forward to an adjustment of my thinking
Legh
de-avatared
 07 April 2011 12:58 PM
Legh
Is the metal wire armouring an effective EMC screen, in my experience it actually isn't - it can be quite "gappy" at certain frequencies
 07 April 2011 01:18 PM
Legh
Legh
Agreed, although I have seen this 'method' of installation used without any ill effects.
I think 528.2 appears to be quite stringent.
Legh
de-avatared
 07 April 2011 05:10 PM
Jobbo
Andy
What cable type is it? STP or UTP. If it's STP then it's generally not a problem.
Jobbo
 07 April 2011 05:23 PM
TeesdaleSpark
According to table 1 of "RECOMMENDED CABLE SEPARATIONS TO BS EN 50174 PART 2" for screened data cables it is ok but for unscreened data cable and a screened power cable 30mm separation is required.
 08 April 2011 09:21 PM
We've got cat5 running near some pretty big swa's around the farms and have never yet seen an issue (the cat 5's are running HD IP CCTV)
The only problem we have is the mice like the cat5 more than the swa.
 08 April 2011 09:30 PM
ant1uk
I can't see any real issues running a cat 5 next to a SWA as the SWA has alot of insulation surrounding it plus its armour. I think you would be hard pushed to find any regulation against this and it would be debated on the above grounds.
I agree that singles and T+E, FP etc should be segregated which is obvious but SWA could be debated that the armour is in itself a containment with added layers of insulation.
 08 April 2011 09:33 PM
Ant,
FP is virtually screened I would have thought, possibly better than SWA by the earthed foil wrap
 08 April 2011 10:08 PM
ant1uk
My apologies stu I meant red FP200 for fire alarms is segregated
 09 April 2011 11:05 AM
Legh
In the process of thought readjustment, a friend of a friend parked her car next to an electricity sub-station. Came back to find the electrical system was completely dead.
Had to take it to a garage to be reprogrammed.
This could be that the EMI generated by the carrier waves outside the 50Hz often used on transmission/distribution systems had affected the car's electronics?
Legh
de-avatared
 09 April 2011 04:03 PM
More likely telemetry transmissions from the sub in the uhf band upsetting the immobiliser and alarm receivers I would have thought
 09 April 2011 04:16 PM
dickllewellyn
I cant see that the insulation of an SWA and the insulation of a CAT5 differ greatly from that of T+E and CAT5 run in compartmentalised trunking?
Richard (Dick)
