Topic Title: Wiska boxes
Topic Summary: Glanding
Created On: 06 March 2019 04:54 pm
mikejumper
I don't use these much.
How do you get a gland screwed fully home without spending 15 minutes filing the hole open?
 06 March 2019 05:10 pm
Just screw the gland in and let it push the soft centre out. You may need your long nose pliers just to finally pull the centre away.
 06 March 2019 05:11 pm
Legh
Screw it straight in with a pair of pump pliers. The gland will take for the first turn and the rest is just brute force.......They were designed like this for quick assembly.
Legh
de-avatared
 06 March 2019 05:25 pm
dustydazzler
As above...
Use an adjustable spanner or plumbers pipe grips to wind in the gland
Some are very stiff and do take some brute force to wind in
I quite like this design as you don't need to faff about with hole cutters
 06 March 2019 05:45 pm
Grumpy
I use them a lot but with SWA you can't use the banjo and have to buy Wiska's pricey earthing bar.
You've got to admire them, they create a problem and then charge you handsomely to solve it!
 06 March 2019 06:43 pm
I've never had any problem with them.
 06 March 2019 08:05 pm
mikejumper
Tried that.
Even with a lot of force it didn't want to screw in.
 06 March 2019 08:09 pm
mikejumper
Is it because you don't use them?
 06 March 2019 08:42 pm
I`ve never had a problem, perhaps you got a faulty one. Screw gland in firmly and blank pops out (mostly) just grab with round nose pliers to break it off.
 06 March 2019 08:46 pm
I have used plenty of them Mike.
 06 March 2019 08:59 pm
The 'combi' boxes have a soft membrane closing the actual hole, and it breaks/tears out as the threaded part goes in.
These work well with the earthing bar or Pirahnas in the larger boxes.
here
But if the thing blanking the hole is hard, they are an older design, and the knock outs need actual knocking out
here
not sure what type you have. note that the fittgins they show on that page only have 2 or 3 turns of thread so dont need to go right through into the box at at full diameter.
 06 March 2019 09:09 pm
mikejumper
Mike, the second picture shows glands with noticeably shorter threads, which look like they're designed to screw fully in to the shoulder without having to break the membrane to do so.
 06 March 2019 09:20 pm
Legh
@Mike,
The second link are for internal fitting and the first link, doesn't work for me, and I suspect are the IP rated ones. I've only used the former for outside and prefer to use Gwiss for internal installs and drill my own holes.
Legh
de-avatared
 06 March 2019 11:26 pm
Dave69
I use whisker boxes all the time when doing outside lights on pubs, but I do find plastic stuffing glands can be a pain to screw in and pop the membrane out so i do tend to wind either a brass bush or a swa gland in first to clear the membrane, takes a few seconds longer per gland but never fails
 08 March 2019 09:31 am
Zoomup
Very occasionally I have to open the 20mm threaded hole with a metal gland if the poor quality plastic one that I am using has weak threads. Then I can just fit the new plastic gland afterwards. But with good quality plastic glands it is normally just a case of push and turn to open the sealed hole.
Z.
