Topic Title: RCD and lighting circuit
Created On: 06 February 2019 06:08 pm
1 2 3 Next Last unread
Nospark
Would you upgrade a CU to include RCD protection(increasing cost) of a domestic lighting circuit if you were adding an extra light that required an additional run of cable(that's not buried)?
 06 February 2019 06:31 pm
chrispearson
No.
 06 February 2019 06:58 pm
BS7671:2018
Regulation 411.3.4 (page 59)
Within domestic (household) premises, additional protection by an RCD with a rated residual current not exceeding 30 mA shall be provided for AC final circuits supply luminaries.
 06 February 2019 07:29 pm
dustydazzler
No
But would recommend a new consumers unit if the old one has no rcd protection
But it wouldn't stop me doing the job if everything else was satisfactory
 06 February 2019 07:44 pm
The new light (domestic) must have 30mA RCD protection to comply with current regulations - that doesn't necessarily mean a CU upgrade though - an RCCB in a separate box would do, or swap an MCB for an RCBO. Unfortunately the option of an RCD fused connection unit doesn't appear to be an option any more.
 06 February 2019 07:54 pm
Why?
BS7671:2018
Andy B.
 06 February 2019 07:57 pm
Originally posted by: dustydazzler
No
I have already posted the requirement above your post:
BS7671:2018
Andy B.
 06 February 2019 07:58 pm
Nospark
I'm inclined towards 'no', unless it's quite simple and cheap to get an rcd in.
But what would one put on the MEIWC in the departures section?
 06 February 2019 08:22 pm
'lighting circuit to previous regs and not RCD protected'
Originally posted by: Nospark
. . . But what would one put on the MEIWC in the departures section?
That your works did not comply with BS7671:2018. Specifically, regulation 411.3.4.
Edited: 06 February 2019 at 09:04 pm by alancapon
 06 February 2019 08:27 pm
2018 surely ? In 2008 it would have been OK.
 06 February 2019 08:28 pm
Nospark
Is it justifiable though? As the regs state something like that a departure must be no less safe than if it was done to the regs.
 06 February 2019 08:31 pm
Read the original post again.
Not installing an RCD clearly contravenes the current Wiring Regulations.
Andy B.
 06 February 2019 08:38 pm
Why?
BS7671:2018
Andy B.
Because if you go on to 531.3.6 which stipulates the type of RCDs that may be used for additional protection, BS 7288 isn't listed (just BS EN 61008, 61008 or 62423)
 06 February 2019 08:45 pm
Farmboy
This seems to relate to the socket issue i asked about the other day, for additions/alterations. SRCD's and RCD fused connection units are to BS 7288. The NICEIC say SRCD's can still be used because they are to a current BS, as per reg 133.1.1, so presumably the rcd fused units are ok to use as well, at the point of the addition or CU for the whole cct.
F
Edited: 06 February 2019 at 08:51 pm by Farmboy
chrispearson
Here we go again - the Regs are not retrospective. We've had this discussion with sockets, but with the 18th, we can have the same debate with lumineres.
 06 February 2019 08:49 pm
But no argument that the addition (at least) need to comply with the current regulations?
 06 February 2019 08:51 pm
Nospark
Indeed, not retrospective. No requirement for rcd protection on existing circuit, but that new run of cable..
 06 February 2019 08:57 pm
Nospark
So is there a justification for no rcd protection for the addition to the cct? Economical, disruption..?
 06 February 2019 08:58 pm
Yes, the new run of cable.
IET » Wiring and the regulations » RCD and lighting circuit
