Topic Title: Dimming from multiple locations
Topic Summary: A bit stumped
Created On: 30 January 2019 02:25 PM
aligarjon
Hi guys. After some advice if possible please.
I have been asked to replace some mk grid dimmer switches with standard switches. What should have been a simple job has turned into a right pain in the backside.
The existing switches don't appear to be dimmers, you hold the switch down and it dims and vice versa, it just springs back to up position. The same lights can be switched or dimmed this way from several locations, however the switching is not wired as standard 2 way, there is literally a live feed and switched live at each switch. There are lots of other cables in the boxes with 3 cores and spare cores everywhere but the actual switches just use the 2 cores.
I was hoping that the 3 cores would just need rejigging to sort it out but one of the 'strappers as i thought' isn't continuous.
I have had a think about it since i got back, i am thinking that there must be some sort of dimming module in the ceiling somewhere that these switches operate from multiple locations, does that sound feasible. Do they do such a beast. The grids are MK swiches i have been searching the mk catalogue to look at their dimmers and can't see anything like it. It has occurred to me that it is probably MK switches switching another make of dimmer.
I haven't come across this sort of stuff before so a bit confused. The installation is about 10 years old.
Gary
 30 January 2019 02:33 PM
Delbot321
Sound to me like a standard "switch-dim" set up, often referred to as "retractive" dimming as the push button switches are retractive switches.
Basically every "switch-dim" light has a dimmer built into the LED control gear. It is not like the old fashion dimmers that were usually at the switch.
As you've already said the lights use a short pulse from a push-to-make switch to turn them on and off. If you push and hold the lights cycle through the dimming up-down-up-down until you release and that's the brightness level they remain. A short push and they switch on/off etc but retain the same brightness level
If you want switches at multiple positions then just parallel up the push to make contact no need for strappers and all that.
Be aware that there is a permanent live to every fitting even when they are off. The push switch tells the in-built controller to switch on/dim etc.
Hope this helps
 30 January 2019 02:36 PM
burn
Or there's a commercial type Lighting Control Module hidden somewhere
burn
 30 January 2019 03:14 PM
And the thing to replace it with if the wiribg is done is the same sort of unit, also available on a normal switch front.
 30 January 2019 03:39 PM
aligarjon
Thank you guys.
Gary
 30 January 2019 05:32 PM
Weirdbeard2
Hi Gary do the dimmer modules have any markings on them? It might be a master switch and slave grid switches as described by Alancapon in this topic? :
http://www2.theiet.org/forums/...tid=205&threadid=49620
 30 January 2019 06:10 PM
alanblaby
burn
Exactly. I've fitted loads of these for offices over the years.
Nearly always CP Electronics modules, and their associated sensors, with MK retractive switches.
Loads of different set-ups are available, manual dimming, auto dimming to keep a set Lux level etc.
https://www.cpelectronics.co.uk/energy-saving-products/lighting-control-systems/rapid/pluggable-lcms
